Turbo P/N needed
264WSM
Wyotana
I'm putting a turbo on from a 94 IDI engine. The rubber seal that goes on the cold side is torn and needs to be replaced. Does anybody have a P/N for this? Know where to get one?? I contacted Garrett 10 days ago, they said that they got the message, but nothing since.
The plate on the turbo that has the model of the turbo is missing. If anybody is running the same turbo, the number on the plate will help.
Can you tell us if the turbo is wastegated or not? If you can post a pic it sure will help.
I should have everthing you need. A complete seal kit with cdr grommet is 83.00 shipped
This forum is lucky to have Russ aka typ4 helping us with parts. I recall he purchased everything ATS had on the shelves when they were dropping the turbo line because of more profitable turbo lines. Kind a sad when that happens.
264WSM
Wyotana
It is waste gated. Pix will be difficult as I'm on the road until Christmas, maybe after I'll get some.
Ramtough01
