Joseph Davis
Just pick up my first Diesel. The truck ran bad when I got her. She was blowing white smoke when I first started her; but all it takes is a good read to figure out it is caused by lack of fuel. So I went out to look over the fuel lines and someone cut out the old mechanic pump and put in a Mr. Gasket low flow sump pump and probable thought it said fuel pump or though it could deliver enough fuel. He Guest poorly. I just went out and got an electric Carter Diesel Fuel Pump and five wire relay kit and installed it. I redid all the lines to 3/8 and set it for 6.9 max PSI on the new Fuel regulator, and wallah; no more white Smoke on start up and no white smoke on heavy acceleration. The motor sound OK but has an exhaust leak so that is my next project. Thanks Oil burners for having the articles on white smoke! I look forward to reading articles on exhaust system so I can put a nice system to match to new fuel system.
