Kevin 007
Full-floater
I have a 99 7.3 with a non functional a/c, its not functioning for several reasons and here in Canada I really don't need a/c at all and never desire even using it so I'd like to remove the compressor and all is fixings to eliminate one more potential failure item and make for better access to other things in the engine bay. Simplification.
Question is, is there an a/c compressor bypass kit and belt that I could buy? Just at a glance, its doesn't' look as if the factory a/c belt idler will work even with a shorter belt
Curious to hear your thoughts. Thanks.
