I just got one of those. Looks to be a direct coy of the Kent Moore Tach-N-Time. Missed my chance to test it yesterday, so maybe I'll get to test it next weekend.
i haven't got to test mine yet either, tried to last Thursday but i could not get the mag probe to fit no matter what i did, hopefully I'll get a chance to look at it again tomorrow
5/16 drillbit on a small pair of vice grips and pb blaster. Work that in the timing hole. Will clean the rust and grime out so the probe can be installed
I can tell that the probe is the exact same size as the Kent Moore unit I rented from Gary, so just make sure you're using the correct tube. Also remember to set the air gap in the magnetic pickup and sand/clean the crank and the spot on the injection line you'll be using.
I still have to finish narrowing the head on a Kent Moore IP wrench IP picked up.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
