joeblack5
Evening folks, I would like to get some guidance from the forum regarding my db2 IP.
1994 E350 ambulance convertedto camper , Quigley 4x4 4, eod , two tank WVO electric fuel pumps 7 psi , HIH, additional injection line heaters full heated return to tank.
At 95.000 miles, 10.000 miles after conversion hard start, heat soak and then no start.
Ip replaced with junk yard unit mileage unknown. but ran perfect. Thanks for the great write-ups about timing and IP removal. That surely helped.
5000 miles later same problem on second IP. Hard start and no start when hot. On WVO hot start is good.
Batteries good, upgraded starter and ground cables. cranks fast, no air bubbles, fuel comes out of return line while cranking.
I tore the first IP down to find the problem but besides a brown coating from the WVO all seems to be fine. Obviously it was not. I found the rebuild manual but that is not very specific about the tolerances of the plungers and head / rotor.
I have to say , it is pretty cool to take an IP apart.
I can see no damage to any of them and so i am starting to suspect that the problem comes out of the transfer pump?
Can anyone give better guidance how to determine the tolerance in the plungers and head and rotor?
Thank you,
later J
Thank you,
later J
