1990 7.3IDI engine block with parts
GadgetTech3D
Des Moines, IA
I have a 90 7.3 that had a main bearing spin on the crank causing it to heat up then lock up. The block it's self is solid and so are the heads and everything else, just would need a new crank and bearings. Engine had 78K on it. I would like to make a little something off of it but feel free to throw a number my way. Located in Des Moines, IA. Thank you.
GadgetTech3D
Des Moines, IA
I was thinking based on what I can find like $300-350? What do you think because I don't know. I know I got a used working motor for $1000 so I'm trying to base it off that. It will come with the engine manual too if that helps :).
GadgetTech3D
Des Moines, IA
What's your ballpark price range?
GadgetTech3D
Des Moines, IA
Correct, I didn't use anything to make the new one run, I got another complete engine to make my truck run again because of time.
William88
