FarmerFrank
if youre switching to e-fuel, I would also be looking at the 99+ hpop reservoir and fuel bowl to do it cheaply.
I have the 99 to rob parts from but I know this 94 runs so I'll run its HPOP until it dies then switch over to the SD.
Is there really much to gain from the OBS to SD HPOP?
And I'll be running my own fuel system. Probably just do the "tight ***" mod to the factory regulator for now and shim it to 60-65 psi.
So far I am just under $1200 in this whole swap project.
That includes parts truck, o-rings, wiring harness, exhaust, intake, intercooler, clutch kit, ZF-5, hydroboost, and other little odds and ends.
As of now it's taken parts from 6 trucks to build this one.
