A few months ago right after installing a new vacuum pump I noticed that at idle I sometimes had a stiff brake pedal or would only get soft pedal for one push and then it would be like I had no vacuum left. But the truck stopped fine at highway speeds and around town so I just ran with it. Today I bought a vacuum gauge to see if my pump was bad but it seems OK. 22 inches vacuum when plugged direct into pump and 21 inches vacuum when plugged into the tree. I am new to diagnosing/replacing the brake booster. With a vac pump putting out enough vacuum for spec is it likely I have a failing brake booster? I had also read something about the booster "check valve" getting stuck/failing. Can the check valve be replaced separately/repaired/cleaned? Sorry for the noob questions but I learn as things break.
