Hydroboost Donors
VandalS
California
the only issue I have with using a mustang hydroboost is the weight of the vehicles.
yes hydroboosters are mostly the same, but the mustang one, I highly doubt that you will beable to bolt the F450 master to it.
which will make you oblong the holes in the master.
and that...
I am not comfortable with... and I do custom stuff left and right.
Thank you, that's what I'm looking for. I'll try for an f450 or chevy truck unit.
I already have the pump with dual return and the mounting bracket for the pump. Just need hydroboost if I'm going to fit the new body.
u2slow
bilge rat
PNW
I put the F-Superduty booster in my '95 F350. I notched the MC holes for fit (fender washers too). I kept the same pedals, but moved the pivot pin up 3/4" for proper alignment. Tee'd the return lines together at the p/s pump.
Stopped awesome after that.
VandalS
California
What year was the booster from? Was it the F-450 booster?
complete kit in the market place for 200
Thanks, but I'm most of the way there already.
u2slow
bilge rat
PNW
'95 F-Superduty (F450)... bought new motorcraft one because jobber ones didn't come with the intermediate pushrod.
VandalS
California
Ok. I found one from a 96. Can't find the older ones, at least not where I've looked.
u2slow
bilge rat
PNW
92-97 should be the same. I ordered from rockauto.... it tells you what years they fit.
Clb
Another old truck
nannyfornia
Still no perusal of the stickie???
I am out.
Boilermaker time.
Clb
Another old truck
nannyfornia
I promise not to spoonfeed you again.
I think you may need to do some quick reading.
One of the nice guys may link it up if you keep asking....
I'm out.
My puter skillz suck.
VandalS
California
I'm out.
I'm good. I've been through the stickies and haven't found one that answered the question I was asking. But I did get a coolant filter and lift pump installed by following stickies.
i think John is confusing the tech articles section with the stickies. I know there's an article or two in there covering hydro units.
VandalS
California
I ended up with one from a 96 F450. The pin is the same as the Jeep brake lever and the rod only needs to be offset 1.5". I'm planning to make a spacer that put's the HB/MC 1.5" off the firewall.
