Ironman03R
I have 2 engines that I have not heard run or know any history on. One is an 87 6.9 that was in a truck I bought several years ago that did not run and had been sitting without a hood. It had water (not coolant) in the crankcase when I drained the oil, probibly from rainwater sitting on air cleaner.
The other is a 7.3 (i think) that I bought from a junkyard and took the turbo off. It has been inside since I have had it, I took out GP's and sprayed oil into cylinders and turned it over and sprayed oil in again for storage. I have not heard it run.
Both engines have all accessories and IP. The 6.9 is missing one injector and the flywheel.
$200 EACH
$200 EACH
