Fellow IDI devotees
I am seeking a higher final gear ratio for my rig. I installed a Gear Vendors, and what a nice difference it makes. Suddenly sitting two feet from a roaring IDI at high rpms in a van body is less brain vibrating at highway speed.
But, I'd like to get my ratio taller.
My rig;
1989 Ford E 350 / Born Free "President" converted to 4WD: 7.3 IDIT (Hypermax) - C6 - NP205 - GV - 3.54 Dana 60s - 16" rims 215/65.
Ideas:
Get a taller differential gear ratio. I have done a fair amount of searching, but am coming up dry. Is 3.54 as tall as you can get in Dana 60's? Is this true?
Put an E4OD in. A lot of work, since it is longer than the C6. I'd have to move the transfer case / GV assembly, and get two new drivelines as well as the electronic brain to run the E4OD.
Get larger tires and or rims. But the front wheels already brush the fender mudflaps when the steering wheel is fully turned. I think I'd have to move the front axle forwards, with all that entails, to make a larger tire fit in the front.
Any thoughts would be appreciated.
regards
Rolf
My rig;
Ideas:
regards
Rolf
