AcIdBuRn02ZTS
Picture of the old style here... first post.
http://www.oilburners.net/forums/showthread.php?33141-air-filter-mod
I wouldnt want to use the older style aircleaner. Wasnt really a choke style.. but had a restrictive plate type thing in the lower part of the housing. I'll see if I can find a pic of one...
Yes.
Search right here on this site.
Thanks everyone for the input. Does anyone know off hand where to find good information on how to advance the timing on my pump to help remove the haze thats coming out my exhaust?
The American Way.Thanks, i'm trying to save myself some time through people who have already done the research and performed this procedure. Im well aware of what a search engine is.
Just found a brand new in the box moose junior fuel pump on craigslist for $650. Should I pick it up to thrown in?
Ok... Didnt find the article but did find a reason as to why it can effect oil consumption.
Apparently, when the air demand of the engine is high, the valve is supposed to close keeping the engine from sucking oil at higher rpm/load. If the diaphragm is ruptured or stuck/sticking, the valve will not close as it should and cause the engine to draw oil. It would do the same if the intake was restricted due to dirty air filter, etc.. the valve should close preventing the engine from drawing in oil. That would explain why guys are claiming a dramatic oil use decrease over longer trips (highway), or pulling loads, etc.. when the valve is cleaned or replaced.
