Dirtleg
So in my quest to obtain a 5 speed swap for my 93' F350 IDI I came across this truck.
It was priced similar to what I am seeing a ZF-5 go for by itself.
The good.
Well it's 4wd.
Seems completeish. (More on that in a bit)
7.3 Powerstroke that does turn over.
New IDM. (Previous owner installed it chasing a no start)
Transmission, at least at rest, seems to shift more smoothly that I would have expected. Could mean nothing. We'll see.
Clutch feels real nice. Smooth strong and consistent engagement and release at least at the pedal.
Has 3 Alcoas in serviceable condition.
Under 200k miles.
The bad.
Previous owner removed injectors while chasing no start. I did get the injectors and they look good. As in stored properly and not dirty or rusty.
Valve covers are in the cab. Not on the engine.
There is some surface rust on the valvetrain.
No idea if there is water in crankcase or not yet. Going to drain the oil and find out.
Been sitting this way for I think 5 years. Yikes.
Really dirty. Needs to be pressure washed.
Truck bed full of garbage.
Drivers cab floor rust.
Bed fender wells rusted out. Fixable I think.
Someone tried to tow it by hooking on to the core support. It is bent very badly at the bottom.
Intake filtration setup completely missing.
Sure there is more bad, but haven't found it yet.
I had to steal one of the tires as I blew a trailer tire while hauling it back so it has one mismatched sized tire on it currently.
Plan is to get it running before I pull the transmission out.
Then swap an E4OD into it and put the 5 speed in the IDI.
That is if it's worth saving.
When my son gets back from deployment it'll go to him. He is constantly sending me ads for OBS trucks for sale and asking which ones are good deals.
The good.
Well it's 4wd.
Under 200k miles.
The bad.
