Tristan
Are front driveshafts all the same or different between manual and automatic trucks?
I was thinking the zf5 was significantly shorter. My e4od to zf swap was in a 94 460 truck but the general setup is the same. Zf6 and 4r100 are the same length, pretty sure the overall length of 4r100 and e4od are the sameThe Cardone 659667 (e4OD) and 659721 (ZF5) differ by about 6" according to rockauto.
Their listing also suggests the C6 and ZF5 use the same front shaft.
every 250 idi ive seen had the double jointI don't think that's accurate, my crew cab was originally a E4od and when I zf swapped it, i used the original shaft.
Only major difference I know of is 250s use a single u joint end, and 350s use a double cardon joint.
Every 250 idi I've seen had a single.every 250 idi ive seen had the double joint
Every 250 idi I’ve seen had single as wellI
