So I was looking a bit into how return lines work on other diesel engines of the same era.
On the Detroit 6.5L, the injectors have two metal nipples that a return line hose just slips onto. Some hoses are made that don't even require clamps. All injectors have two nipples, so a cap is placed on the injector(s) at the end the line. Leaks are reportedly pretty rare and easy to fix.
On the Cummins used in Dodge Ram, hard lines are used with banjo bolts. The attachment is at the back of engine and very hard to get to. Leaks are basically unheard of.
And of course the 7.3 uses this rinky-**** system of o-rings and plastic caps that will leak if you look at it funny or forget to sacrifice a chicken before installation.
So my question is: Would a detroit injector fit (and work) in a 7.3 (doubtful), or does anyone make an injector of the Detroit style that will fit in a 7.3?
If I could find such an injector I would gladly install them and never look back.
