Interesting no clutch disengagement
Austin86250
idaho
I found a pic of the old clutch that worked great and the tounges on them are good and flat while torqued and the. Second one is a brand new torqued zf5 clutch also flat
This kinda confirms my suspicion that that pressure plate is off somehow
Austin86250
idaho
While the play in the clutch pedal isn’t great but i once used a bolt as the clutch pin fell out and had Much more play than right now and it still disengaged
And I don’t think the slave is moving nearly as much as it should
ROCK HARVEY
Dayton OH
When you removed the pressure plate, did the tongues raise up as you loosened the bolts? Or were they already all the way raised with the bolts tight? I’ll have to get under my truck and look at my slave movement, but yours looked like it should be enough to disengage the clutch.
Austin86250
idaho
They did not when I loosened which was weird as usually when one bolt is loosened that side is aggressively my raised compared to others
If you could grab a vid of your slave movement I’d love that the only other manual I own is a m5od with that internal slave bullsh*t
Rdnck84_03
Kansas
It should push itself out if I remember correctly about 3/8" or more from the flywheel when loosening the bolts. I'm thinking a little more than half the length of the bolts are under tension.
Does the diaphragm set level where the throwout bearing rides when not bolted up? I am thinking something is wrong with that pressure plate. I am still thinking it sounds like a broken diaphragm. It is kinda hard to inspect the diaphragm but when mine broke it was up inside at a hole where it was riveted to get outer cage
James
Austin86250
idaho
What can cause a bad pressure plate? If it turns out to be the pressure plate I’d like to know why that happened
Rdnck84_03
Kansas
The one I had break the diaphragm was probably 20 years old so i would assume it was just worn out. But with any of the new stuff my guess would be that they are manufactured with inferior material, and the diaphragm wasn't heat treated properly.
James
Looks to me by the video, you have a lot of movement before the clutch rod hits the MC to activate the Slave.
I have mine adjusted so I have the smallest amount of plat w/o any pressure on the TO Bearing.
Austin86250
idaho
The play is within the pedal assembly not the pedal assem to master linkage
Rdnck84_03
Kansas
I don't remember the part number of the ones I bought but they were Dorman and looked like that assortment.
James
Austin86250
idaho
Bolted the “suspect” pressure plate on springs maybe compressed 1/8” and where all weird and uneven to each other
Bolted on my old one that did work and all the springs went down a solid 3/8” and where even to each other
and to make it even better I can’t find just a pressure plate at napa I’m going to have to buy a whole kit unfortunately… I’m done buying from Rock auto this is the second clutch kit I’ve had issue with from them maybe y’all have better luck but I do not
On a positive note my russ goodies came today new stainless clutch line, hardline delete kit, and the new injector to fix that dreadful knocking
Rdnck84_03
Kansas
Good to hear you found the problem. Really sucks not being able to warranty a fairly new part though.
James
Austin86250
idaho
Got those lines on
ROCK HARVEY
Dayton OH
I’m not sure how helpful it is, but here is a photo of my slave cylinder travel on my ZF-5. I have a video, but I don’t see a way to upload it so hopefully the pictures give a good idea.
IDIBronco86
Staff online
