bulletpruf
7.3 build continues - got the crank in with no issues. Endplay of .005". Main bearings at .002". But now it's time to install the piston rings, and the oil rings are new to me.
Is there a trick to install them? From what I can tell, the expander type deal fits behind the ring, and it's got green paint on it, so that's the part that must face the oil ring gap, right? Do you install the expander first and then put the ring over it or should I do both at the same time?
I'm using Total Seal rings. Standard bore NA 7.3 pistons (original).
Thanks
Thanks
