Bart F-350
I have had a look around the vacuum switch, and I coudn't find yet a bare wire or bitten vacuum hose, nor any rodent damage underneath the dash.
Unclear to me from your post how many miles are on this filter. Did you stop driving it after 200, and it's been sitting there for 3 years? Could be green goop grew in there. Use Howes or another additive.Three years ago I changed the (still original) fuel filter for a new one, I only drove 200 miles in the beginning of that period.and after that no more.
now the "fuel filter" light in the bottom RH corner of the instrument cluster comes up, if the engine revs over 2000RPM, and I wonder if someone here can tell me what cause that could have?
1989 F-350 7.3L Diesel
Where do you get fuel filter for $6 by the box. Man I must be internet searching dumb!!!!I get IDI filters for about $6 by the box
That is pieces of your shower head in the bottom of the tank i have that as well if i run my front tank, as for me i need to change my sending unit n flush my tank after winter goes awayOhhh yes!
I'm in for a lot of work, the diesel pest has hit here!
lots of black flocks of something in the bottom of my filter!
what to now?
No I can't (for the moment) since tuesday I have a roadworthyness test, and I have no other replacement filter for the moment. sorryCan you post a photo of the junk in your fuel filter? Cut it open.....
