I have a 60 size oil pressure operated type centrifuge, I see the larger motor driven fuges available over there,
Has anyone tried the 2 types side by side too see which is more effective, well basically too see if these little pump driven units work anywhere near the same as the other??
Forgot variables like heat or thinning or settling let’s assume anyone using a fuge had a good system in place already, fuge vs fuge
