There is a thread over on FTE where a 6 Digit Speedometer has been discovered on E-Bay.
As you know out 83/86 only got to 5 digits and roll back over to zero`s and does not show the 100K 2, 3 etc....
Why Ford put in a 5 digit in the 150, 250, 350 trucks, but get to the F600, 700 and 800 they installed a 6 digit.
The Instrument cluster is the same exact same one installed in the smaller trucks.
I did post this at the end of the thread, currently running.
"I Present the 400,000 mile PSOM/Odometer"
Good old E-bay they are $200 and saw one for $400, where at PNP you can grab one for around $40 bucks.
Majority of the bigger trucks are gassers so the tach won`t work, but Ford did install a Cummins in the 700/800. We had one where I worked.
Iam more interested in finding just the Speedometer.
Would this instrument panel work in my 84 f250 6.9l - Ford Truck Enthusiasts Forums
Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Would this instrument panel work in my 84 f250 6.9l - This came out of a big truck. The odometer mileage goes beyond 99k. But everything else looks identical. I'm wanting a tachometer on my panel....
www.ford-trucks.com
