1989 F-250 7.3 Project
hacked89
Bucks County PA
Coolant system is fixed. New thermostat is 195 open start and assuming 212 fully open which would align with the book. Idled the truck for 2 hours and it just bounced between 211/212. Everything else looked good.
hacked89
Bucks County PA
Last two times I opened the coolant system I’ve used the harbor freight vacuum filler and it is well worth the $80 for your time, purging, and testing the system. Bonus points the default tool fits right in our radiators without an adapter. Made a short video on how to use it.
That is a slick way to fill the system. Never seen it used before.
Thanks for making and posting the video.
Now here is one more tool to add to the inventory.
The_Josh_Bear
Western WA
Very cool! Never seen that before and it's quite a good setup. Thanks for the video!
hacked89
Bucks County PA
Finished the rear harness of the truck and lighting. Everything works. Reviewed the diagram for the reverse lighting, spliced together a C6 harness and a ZF5 harness to make the reverse circuit. Essentially just had to cut a female connector out of the ZF5 harness and flip it on the C6 side. One of the pics was the temporary wiring for the connectors. Last thing I have to wrap up for the rear is the license plate lighting.
William88
