"Brownie Box" Aux Trans Questions
Which would you use?
  • 3 sp. "Brownie"
    Votes: 7 41.2%
  • 4 sp. "Brownie"
    Votes: 4 23.5%
  • GV Unit
    Votes: 2 11.8%
  • US Gears Unit
    Votes: 4 23.5%
  • Total voters
    17
Jake2670
Alma, AR
well, I got pics today, but can't fig how to post, I put em on my google+ page, n got vid to put on YouTube, Jake2670 on both
Jake2670
Alma, AR
Here is the info on the Box my friend has. I have pics n vid uploaded on DropBox https://www.dropbox.com/sh/jlezogypx...ks old gmc so they can b seen there, hate can't post right to this site cause most prob won't go there n really like to find out what this is, guess I'll just put all the #s here that r on the case looking at case from inside to outside of box, writing running up n down 1st row - a circle n looks to b "CFD" 2nd row - "229or08545" then circle made of dots with teardrop in middle 3rd row - has a raised tab with 310 or 3-10 on it then what looks like a 53. I had said this was a 48, but he said its a 54, so I'm thinking this 3rd row may be the manufacturing date.
thanks for the help guys,
Tgould
western WA
i see that this is an older thread but i have a 3 spd 5531 brownie that could use a rebuild, is there anyone near western Washington that is familiar with or can point me in the right direction?
edpruss
Longmont/CO
Brownie trans. Come in sizes, first number indicates TORQUE rating of ENGINE I. e. 500 ft. lbs. of 5531, etc. OK for early 5.9. Anything larger than 6000 series is too large for most vehicles, unless one has an oilfield truck. The third number indicates the number of speeds, I. e. 3 in this case or 4 in 6241, no gears are synchronized, practice your double clutching, works easily. All are designed for divorced mounting. Some do not have a rear seal, just reverse threads which do not appear to be a problem.
They are shifted by two rods going fwd to factory shift tower which has many bolt holes for mounting brackets. Best to get one of these, although one could be made(see top of frame in picture.) Shift linkage can be .5” water pipe or 1“ EMT. Speedo output on rear of case.
Trans. mounts to two factory crossmembers that are rubber mounted to truck frame. Input side has a rotary mount that allows the rear crossmember to take the torque load. Mount could be replaced with short section of 6” or 8” heavy pipe attached to crossmember. Rubber grader blade mat’l (1” thick) handles vibrations. Rear crossmember handles torque and park brake(TrueStop, new pads available near Denver, CO) mounting. Very complicated to replicate. It is best to have a park brake, unless one has spring brakes. Probably illegal, too.
One can be mounted from beneath, but it is a lot of work. A good excuse for mounting would be to occupy the location of aux. accessory like water pump, etc. in middle of driveline. Of course one needs two splined driveshafts, etc. Normal shifting
Ed
William88
