*****************Trans Cooler (cont.)****************
Built a stable frame for the cooler:
First part was to make some sloped pieces
(view looking aft)
1/8" thick flat stock bent to fit, lots of Nutserts (1/4-20)
Hardest part was figuring how to get both slope pieces to hold the
same angle, since that part of the van is NOT square anyplace!
Lots of head-scratchin'
Sub frame for the cooler:
(view looking fwd)
I shot the Frame with Rustoleum "Textured Black," good stuff.
*note the rubber vibration isolators (1/4-20, double ended studs)
Cooler and Fans bolt to the rubber shock mounts, nylock nuts:
Will be covered by a mud guard and bash plate.
*****************Trans Filter******************
Next area aft of the cooler located the Hayden 2106:
Used (3) 1/4-20 Nutserts into Body Brace:
(view looking fwd)
Unit mounted:
Ready for spin-on filter
******************Line Schematic****************
With all the main pieces in place, a plan was created to organize
the lines and connectors needed to hook everything up:
This was designed to facilitate field repairs, allowing for temporary
bypassing to limp home. Flex line was implemented to isolate vibe
loads, and hard line used in places to promote additional cooling.
Parts are ordered.
****************Rear Driveshaft*****************
Part of the adaptation of the E4OD/BW1356 was a new driveshaft, which was
necessary since the 2wd C6 was over 8 inches too small, the E4OD PLUS the BW1356 is huge by comparison.
The original driveshaft was DESTROYED. This was the reason for a complete, new, shorter rear driveshaft.
Post #162 shows the specs I came up with:
http://www.oilburners.net/forums/showthread.php?69057-1998-E4OD-on-the-outside-wait-a-minute!/page11
I changed them a little, keeping the front end a Double-Cardan style joint then the rear end I increased
to a Spicer 1350 (1.188 Cap Dia.) The plan is to upgrade the Rear Pinion Yoke from 1330 to 1350 (axle
is a FF D61, the hope is to put a Detroit locker in.)
The rear output on the BW1356 was converted to a Non-Slip Yoke style Flange. The Driveshaft would now
have the slider toward the aft end.
Double-Cardan allows for high angles, and more important, better harmonics because
the input and output to the Driveshaft do not have to be parallel (they never are all
the time in real life, due mostly to axle wrap-up, and articulation.)
I had to purchase a 1350/1330 hybrid Spicer Joint as a temporary solution until I get the rear pinon work done.
I prefer U-Bolts over Straps.
Slider has screw-on wiper, outer boot is not necessary.
Internal splines are coated with the Ford Blue Teflon. Build quality of the driveshaft appears excellent, will report
on function after road tests (welded on balance weights are apparent.)
The plan is to lube all zerks with Mobil-1 Synthetic red grease.
That's it for now.
Best regards,
George
(view looking aft)
(view looking fwd)
(view looking fwd)
Unit mounted:
Parts are ordered.
That's it for now.
Best regards,
George
