No blinkers
Austin86250
idaho
86 f250 6.9
Sorry if this is off topic as it is not an idi related question but I’ve exhausted all my other resources
Last night my blinkers stoped working this had happened twice before about 6 months ago but they came back after 10 minutes it so but this time they continue to not work
No blinkers but the stock clicks down and returns like normal and hazards work
I’m not sure what ground I should clean but Facebook said to clean the ground so I cleaned every ground I found to no luck
From what my research brought up the issue is most likely the flasher so I replaced the flasher still nothing I took the the hazard flasher (known good) still nothing
Since the hazards work as should as-well as the the lights that rules out any of parts shared by the blinkers and hazards
I have not been able to get to the turn signal switch as I’m not equipped for that as I’m out of town and am limited to my Costco dewalt toolkit
Any help, input, edc. would be greatly appreciated
Cubey
Van dweller
(i need to brush up on reading comp. asked something already addressed above)
gnathv
Athens, Al
Check fuse #5
Austin86250
idaho
THANK YOU CUBEY AND GNATHV! fuse 5 was blown but a thing to note is there was a 20a in its place (should be 15) i only had 10s and 20s on hand so I had to throw a 20 back in but regardless they work again now I can get back to my door seals in peace
The_Josh_Bear
Western WA
Did you check the blinker fluid reservoir? When they get low you run into all kinds of problems... :rotflmao
Glad you got it worked out!
Austin86250
idaho
that was the first thing i check i did a super flush and added fully synthetic back in thought that was the issue but at least i wont have to worry about it for at least 30,000 miles but man did that hurt the ole billfold blinker fluid is getting EXPENSIVE these days
ibapaine
Blue Ridge VA
For future reference, their is two fuses (the big round one) plus the 15. The front round fuse is for the blinkers. The one in the back is for hazard(very difficult to put back in). If you upgrade to heavy duty you will have to loosen the bolts to get the new fuse in.
You can switch them out if one is working and the other isn’t to troubleshoot your problem.
