fs5306a or zf5 adapter
gonecrazyi
florida
What would you choose and why.
I already have a 91 cummins but have have a chance to get a 96 p pump with the fuller non overdrive tranny for 1800. Id also have the parts needed of I found an overdrive tans.
The adapters for the zfs with clutch and flywheel will probably run me around 1500the or so. I would also have to get a divorced t case for the fuller.
Opinions would be great.
BC4Lyphe
United States
Hi ive got a fs5306. wonderin if youve got a list of parts or part numbers id need to get overdrive 6th gear
WECSOG
Alabama
I would get the 5306A. Much heavier duty trans, and more different transmissions that would fit that bellhousing and adapter.
tottripp
