trythis
Now what this truck is doing we started out cold engine it runs pretty good you get up around 1500 RPM and you’ll start noticing a miss it’ll run like that for 10 or 20 miles. It’s warmed up pretty good at 5 miles. Now you’re getting that miss but it is tolerable. Then it starts getting much worse until it won’t run. If you let it sit 30 minutes it’ll start up and go again another 10 miles or so.
The truck has had the misfire issue for months, this issue with a dying has just started.
