TygreII
OK, I have a '92 F350 with the regular axle in back. The springs on both sides have cracked and/or missing leaves. I need to replace them.
I would like to use this truck to haul a 12k 5th wheel. I believe it can with no problem after the spring problem is fixed.
FYI: I have a banks turbo and the 5 speed manual trans in it.
Which springs should I consider putting on my beast?
