Congratulations on your little Girl.
You won`t be seeing these much
some one else has dibs on them now.
A few winters back, the Water Pump
started to leak. And being cold just took
it to a shop. They called and said the
Power Steering pump is leaking, and the
Valve Covers. Being in there, why not?
I knew they were leaking.
A year or so later, the drivers side started
to leak. So pulled ea bolt out, blew the
hole out and cleaned off the bolt threads.
Then used Loc-Tite, and it is still dry.
It`s been over 2 years back. The Pass side
is a mess, just haven`t got to it yet.
So use some Loc-Tite on those bolts.
