Let's see if the simplest of criteria in search works....
https://www.oilburners.net/threads/introduction-to-the-idi-tech-forums-all-newbies-start-here.5387/
https://www.oilburners.net/threads/electric-lift-pumps-ip-and-injection-timing.76503/
https://www.oilburners.net/threads/carrier-pump-group-buy.24142/
https://www.oilburners.net/threads/fuel-return-flow-acceptable-psi.86249/
https://www.oilburners.net/threads/favorite-mechanical-lift-pump-brand.85524/
https://www.oilburners.net/threads/post-up-your-custom-fuel-pump-filtration-setups.84100/
https://www.oilburners.net/threads/official-test-results-of-fuel-inlet-presure-timing.34636/
https://www.oilburners.net/threads/fsv-tear-down.50770/
https://www.oilburners.net/threads/upgrading-to-electric-lift-pump.87063/
https://www.oilburners.net/threads/...th-a-facet-duralift-electric-fuel-pump.54496/
https://www.oilburners.net/threads/converting-mechanical-fuel-pump-to-electric.59242/
