HELP!!!!!!!!
Kraig
Louisiana
Please help. I think I just completely screwed my engine but I need yall to tell me yes or no.
I was installing the freezplug in the top of the engine and it went in WAY too easily and went almost all the way with a light tap. Well needless to say it fell all the way in.
I'd love for someone to tell me Im not completely screwed but I am thinking it's over. Like I just put this engine in a couple of months ago and have been fighting fuel problems. So I thought e fuel would be the bees knees.
please give me any advise you can. Thanks
Kraig
Louisiana
Update, I hand turned the engine over and I heard the freeze plug clearly hit the bottom of the pan. Thoughts on leaving it there or trying to pull the starter and pulling the dipstick adapter and tryin to fish it out?
greenskeeper
PA
If you're certain it's at the bottom of the pan, it *probably* won't hurt anything. I state "probably" because although the pan is deep, there's still a round metal disc where it doesn't belong. I would most worry about it getting sucked up against the oil pickup tube.
You could try going in through the dipstick adapter, but that also has parts that could fall into the oil pan. Proceed carefully if you go that route, if you can take off the adapter without dropping something else into the pan, then I'd say you'd probably be fairly successful with fishing out the freeze plug with a magnet extension.
Kraig
Louisiana
What's the best method of holding the dip stick tube adapter? I've heard a gun bore brush? Coat hanger? What would you recommend
lotzagoodstuff
Carmel, IN
One other thing you could consider, even if you end up going through the dipstick tube, is having your truck someplace where you have access to compressed air and a welder. Plenty of folks have cut a hold in the pan and welded it back up rather than pulling the engine to remove the pan. You might even see if you can find a local welder who can do this rather than touching the oil pan dipstick at all, but that's your preference.
Good luck whichever way you decide to go.
https://www.oilburners.net/threads/base-of-dipstick-tube-fell-into-oil-pan-help.32281/
greenskeeper
PA
I've never removed/replaced the dipstick on either of my trucks so I've got no advice from experience.
Kraig
Louisiana
Ok update:
I used a bore brush for a gun to hold the oil dipstick adapter. Worked perfectly. Through a lot of praying I finally got the freeze plug out with a magnet. PRAISE THE LORD! And the dipstick tube adapter went back on easily.
so I did not have a repeat of the last I ended up cutting the old fuel pump up and threading the hole in the top. I tapped it to a 3/8 bolt and covered it in permatex and thread tape. I then strapped the blue banjo fuel line adapter right on top of it and bolted the whole affair down. So the Underhood work is done.
thank you all for your help.
Kraig
Louisiana
Ok so e fuel is installed and the truck starts much better but still has a 3-4 second crank time and a bit of white fuelly smoke. Any ideas?
Can't keep up with the different threads.
Verified glowplugs operation? (Relay, each glowplug, uvch)
Sent from my SM-G988U using Tapatalk
Kraig
Louisiana
I apologize for not being able to keep it all together. I have had multiple problems and have had to fix them one my one.
My glow plug relay is functioning. I will have to check my glow plugs again.
greenskeeper
PA
Do you know the condition of the glow plugs?
If not, you should pull them and inspect (or replace for under $100).
I've seen glow plugs test "good" with a meter, but when 12v is applied they hardly glow at all.
Is your block heater working? Have you tried plugging the truck in for at least 3 hours?
How does it start when up to full operating temperature? The same 4 second crank?
Kraig
Louisiana
Ok. Changed the glow plugs with motorcraft. Also swapped out the engine harness as I found two burnt plugs for the uvch. The truck starts and runs even when cold. It still hesitates right at startup oddly. I'm wondering if this is fuel presssure related. I did a custom e fuel on it with a Walbro pump and the pump is only powered when cranking and with oil pressure. I wonder if the lag in starting is related to the pump only starting to build fuel pressure once the engine starts cranking.
tottripp
