Hey y’all! Haven’t been on for quite some time, but I’m making my comeback. A couple years ago some engine internals decided to exit through the oil pan while I was cruising on the freeway. I don’t know how many cylinders were taken out, but she still started right up and ran, still had great oil pressure, but shook so bad it damn near rattled my fillings out. Prognosis pending, and I will certainly be sharing what I find once I pull that engine out and do a tear down. Truck was towed home and has been sitting since.
I’ve finally gotten around to building the new engine for my truck over the last few weeks. Went to the junkyard and pulled a 6.9 out of a truck that appeared to have had a tree fall on it, so I figured it wasn’t in there for a dead engine. Came with an ATS 088 setup (for sale soon, T19 trans), same one that the blown motor has on it (also will be for sale, pending inspection for condition/damage, T19 Trans).
The last engine was routinely being fed over 10 psi and peaking at 14 from an unmodified ATS 088 Turbo and N/A calibration IP... with stock head bolts. I’m kind of surprised it held up for as long as it did. So, ARP Studs were the First thing I ordered. Being the type of person I am, that means I definitely need to put a bigger and better turbo on it, and also something that hasn’t been done on an IDI yet. I ended up winning a low mileage takeoff Holset HE341 on eBay for cheap. So this turbo is basically an updated and better flowing HY35W, which from what I’ve gathered from reading about other people’s experiences is that it’s great on the cold side, and will spool up instantly with its 9CM exhaust housing and 12 blade turbine wheel, which is what I want/need since I have a manual trans. However, I know that it wasn’t going to flow enough for a 6.9 and would create unacceptably high EGTs with that small turbine wheel and housing, but I did some looking around before I decided on which turbo I wanted to try out. I chose the HE341 because they’re cheap and Cummins guys toss em for the HE351CWs due to the bigger compressor wheel, but they share the same hot side of which there is an upgrade available to remedy the flow issue. So now I have an HE341/HX40 Hybrid, and I have faith that it’s going to perform well on my 6.9...
Im going to make it fit in the same place any other aftermarket turbo would be and run a 3” downpipe. Going to Initially try a spring on the wastegate since the wastegate actuator that comes on these turbos is set to 38 psi.
