Rattlenbang
It's progressively getting worse. 7.3 in a 89 F250. Bought it with hard starting problem, that wasn't that bad but suddenly a week ago a lot worse, even though I've been trying to fix the problem. It had 2 bad glow plugs screwing up the controller, so I thought that would be it, but nope. replaced the plugs and it started easier, but I have a 6.9 in a motorhome and that puppy lights up in less than a second of cranking even after sitting a month.
After replacing glow plugs a month ago it would take 10 secs of cranking. Now it suddenly takes twice that, and when it starts a big plume of white smoke.
If I give it a small puff of ether it starts right away. Once it starts it runs like a gem, starts instantly rest of the day. No smoke.
I was convinced it was a glow plug problem so I checked each plug with a meter and they checked ok. I replaced the wire ends with new glow plug connectors and checked for full continuity to each from to controller. 2 new batteries. Decided to bypass the controller with a switch and a heavy duty relay, and now measure almost 11 volts at each plug when cranking. So it's not a glow plug problem.
Starter spins it fast. Starter and battery cables are good.
Decided it has to be a fuel problem - air leak. PO has put a new o-ring kit on injectors with new fuel lines. To test for this, I clamped off both fuel line and return line to keep fuel from draining into tank overnight - no change. I figure if air is getting in, fuel has to be draining, which it's not. Most hard start problems are fuel draining away when sitting but in my example it can't be. Doesn't appear to be leaking anywhere I can see.
The only other thing a bit off on starting is that when my 6.9 starts it immediately runs at fast idle. With this 7.3, although the 2 solenoids turn on, the truck has to run a minute or two before the idle creeps up to fast idle. The 6.9 has a rebuilt IP.
The 7.3 has about 250k kilometres on it. Original IP.
I'm quickly running out of options here, as it seems I've tackled the common sources of start problems and no improvement. Tonight I clamped off the return line to the fuel filter head as I have no idea what else to do, but I doubt that's it - you have to have fuel draining to create the vacuum that lets in air, and I've already eliminated that as a possibility.
