Hyrdroboost or steering gear
Adrenaline73
Idaho
I have a 2004 f250 4x4 so about a week ago while turning into my drive way the steering gear box bolts broke so got it fixed. But now when steering or pressing the brake pedal you hear a whining sound. Also the brake pedal is getting hard to press by the day. Truck is on a 6in lift with 37s any help would be greatly appreciated I’m stumped
Philip1
Northeastern Nevada
A whining noise from a power steering usually means 1 of 3 things, air in the oil, a restriction on the suction side of the pump or a worn out pump. I would check the hoses for any wet spots, kinks, or any other damage. Then check if the oil is foaming at all.
Adrenaline73
Idaho
will do I’ll check that in the morning and see what I can come up with
Ramtough01
