Just added a hypermax intercooler, can't reach fuel filter..
DiecellDan
Tx
Just added a hypermax intercooler and can't access the fuel filter. Any suggestions?
It could even be mounted along the frame. Even though I don't really like the idea myself, I'm going to be doing it in the future.
are there any kits for this?
I will say that my biggest thing to be paranoid about this is the possibility of something being thrown up off of the road and puncturing a filter. When I do this, I'm going to put a metal piece in front and probably underneath the filter/s for protection. My other big gripe is having to lay underneath your truck to change the filters, but it's something that I cam live with.
Scotty4
My eventual goal is to have a flat bed and in one of the boxes below, have a dual filter sytem and maybe selector switch moved in there so its easy to acces on its own and protected.
Scotty4
That's actually a pretty good idea. I don't want a flat bed though so it won't help me.
Truck toolbox and just partition an area off to have a fuel system in there? If you placed it high enough to be the highpoint for air venting it would help too.
Sent from my SM-G950U using Tapatalk
With my loading, not to mention the slide in camper, I don't want a bed mounted tool box either. I could basically build a metal box along the frame to put the filters in if I wanted to.
genscripter
Inglewood, CA
I'm sure it can't be that bad in a truck. Try accessing anything behind the banks air intake system on an IDI van.
tjsea
Lickdale, PA
Just install a flexible hose instead of hard line from the filter to the pump. Conestoga sells a kit for this reason, but you could probally make one pretty easy yourself.
Suddenly
Edmonton AB
Got a picture? My intercooler piping interferes with my air cleaner, all I do is undo the clamps and rotate it out of the way if I need access. How often do you need to access your filter?
William88
