wiring diagram for 1989 ford 7.3 IDI
Dan Keating
NY
I am looking for a wiring diagram specific to the fuel system. I am looking to to take out the fuel tank switch and just run one tank and reconnect the the fuel gauge. any suggestions?
greenskeeper
PA
I'd guess that the harness at the tank selector is what you'd need to rewire. Determine which pair of wires goes to the sender for the tank that you are going to keep and wire those directly to the sender in that tank. In the cab you could eliminate the selector switch in the same way. Should be pretty straight forwards IMO.
William88
