So I have a friend who picked up an 87 F250 4x4, I haven't seen it in person yet but he's been going over things and can't get it to start. He's so far put on a facet pump, @Thewespaul 's feed line and fuel pressure gauge, pulled injectors and put in new copper washers, cleaned injector bores, new return line kit, new olives, new batteries, and new cables. He put in new glow plugs but put in diesel rx plugs (we can always fix that at some point) and the best he's gotten was some white smoke.
Being that it's an 87, I haven't seen it yet but it sounds like it's a 6.9 as he's put on a doner injection pump from the scrap yard and mentioned pulling the oil fill to remove the bolts to pull the pump (thankfully the timing gear and housing and everything have stayed put).
I'm guessing from what he's done his glow plugs aren't working at all, being that it's an 87 does it have the goofy temp sensor thing that fails on often still? I know 87 is a fun year and I've never messed with one, I'm hoping I can manually trigger the glow plugs after I test those and we can get it to fire. Going to check that the FSS is working and we can get fuel to injectors. Also can't remember if 87's have the 6.9 water separator on the firewall that sucks or not either.
