if you are familiar with cu-ni brake line it is much easier to work with. amazon has the cheapest price and comes with fittings, including the fitting for master cylinder. you can buy a roll of 3/16 and 1/4 inch for what autozone wants for the 3/16. you will need a piece of 1/4 for line from t-fitting on axle to right rear. i will tell you this job is not easy to do with bed on however as access is limited. hope this helps. steve
I'm unfortunately no stranger to changing brake lines, living in the salt belt. There's no pulling the bed off on this one, it's a box van just laying on the ground getting rust in your eyes for hours, covered in sweat and brake fluid.... Can you tell I hate brake lines
I ordered a 50' roll of the 3/16 CuNi line on Amazon yesterday for like $38, DIRT cheap. Got a bunch of fittings too, including the odd 7/16 fittings and 1/2 for like $10.
Whatever I don't use on his I can use on mine when I get the frame all cleaned up and painted.
