Picked up a 1985 F250 IDI from a guy that could not figure out his brake problem. He dropped the price from 4000 to 1200 and delivered it to me! Now I cant figure it out. The PO replace the master cylinder, the brake booster, the front calipers and a front brake line from the master to the proportioning valve. This truck does not have RABS. First off the pedal would not return when you apply the brakes, So I checked to see if it would return if I disconnected the booster vacuum, it did not. So I bled the system and it seemed to work, NOW the pedal is hard and the truck barely stops. There is good vacuum ( do not have a vacuum gauge so I cannot measure it)
Thank You for any help you can give me.
