Installed my gauges and decided to tap off the unused roof marker lights wire. I removed some insulation, soldered on two 18ga wires coming from the pod and another on the dash and then grounded all gauges together on a good chassis ground. Initially my first test was good until I got everything back together and got no lights. Very dim dome light. Decided to check links and found the black with orange stripe link blown.
I had put the key in the ignition and didn't even get the door buzzer and it can't turn over. Safe to assume the link was on its way out and the extra draw killed it?
Best replacement? Any help would be great, wanted to do a dump run tomorrow!!!
