The_Josh_Bear
Be aware that if the mechanical pump's diaphragm ruptures that electric pump will then pump fuel through the diaphragm into the crankcase. Which is why they should be on separate circuits!That sounds like a good idea, if you're going to buy an expensive electric pump that can actually replace the stock mechanical pump. I'm too cheap to go that route, and I really don't like depending on electric stuff, so I bought a $50 electric pump and put it in the line between the mechanical fuel pump and the selector valve. It will push fuel through the mechanical pump to prime the lines, and it will let the mechanical pump suck fuel through it when it can't keep up.
