JFlay
Hey all, I'm new here and recently purchased an 89 F350 supercab dually, with the 7.3 idi and c6 trans. So far the truck drives fantastic, all the exterior lights work, even the horn. But that's about it.. The wiring under the hood and under the dash is a HOT MESS. It has trouble starting and sometimes needs just the littlest squirt of ether. Unless thats bad and I shouldn't do that? Ive been reading into the glow plug relay and such, but moving on.. once running, it won't shut itself back off. The fuel pump is bypassed with an electric one, which I have verified shuts off with the key because its distinctive noise quits. But it keeps running. I've began looking into the shut off solenoid, which I think runs along with the glow plug solenoid? I also saw the high idle runs with that as well. BUT. After idling for a little bit cold, it idles down to normal, as if that switch was working.. I haven't the slightest whats going on there. There is shady looking wiring all over under the hood, I'll add pictures later! Next, only the tach, battery, and oil pressure gauges seem to work. Nothing else. I've investigated the speedometer and found the issue there with a messed up cable. Easy. But I'm clueless on the rest. Also cruise control doesn't work.. The radio doesn't work, but lights up. I'll add that the fuses that are present seem fine. But there are a few empty slots? Moving on.. I have trouble filling the front fuel tank.. It won't vent properly it seems. The rear tank neck isn't even there. I don't even see a second tank under the bed?? I hope I don't sound like too much of a newb.. haha. Oh yeah, on the air controls, only defrost vents seem to be functioning. The different fan speeds work for that mode, but that's it. AC doesn't do anything, and I know the heater is bypassed under the hood so hot air wont come either. I figure the heat exchanger was most likely clogged or leaked.. I know this is a lot, but it will be a fun project to tinker with for a while, and any and all advice for any of these things will be MUCH appreciated. Thanks in advance!
