I showerhead tested my front tank today. I didn't realize that it was that low on fuel until I got on the highway heading home. My choices were turn around and get fuel or keep going for another 20 miles. I kept going. I put 14.5 gallons in without any running issues so I guess it's probably still there.
Exhumis
Virginia
Used a bfh to reduce a big ass dent down to a little ass dent in the tailgate. Least it closes correctly now.
Began work on the double din install. Hope to post a write up when finished, been taking pics along the way.
Exhumis
Virginia
New dash bezel with new Mc fuel switch and new to me wait to start light.
chillman88
Central NY
Didn't do much, I knew rain was coming. I straightened out a bunch of bent fins on the AC condenser on Diego. Then I drilled the grille and screwed in the snaps for the grille blanket/bug screen.
Trans cooler should be here tomorrow, then if the weather agrees I can start putting stuff back together.
I plan on flushing the system with Vinegar and water before flushing with water, and then refilling with ELC.
lsaami
MN
Yesterday I sanded all the rock chip rust spots on the passenger door, and shot a coat of primer.
William88
