Does it come with bolts to use in the torque convertor or do you have to source those yourself?
It came with 6 flanged bolts for the torque converter so it could be installed with a 6 hole flexplate or four hole like the IDIT flexplate. Wish every e40d torque converter had bolts instead of studs, much easier to install and to check clearance between the torque converter snout.Does it come with bolts to use in the torque convertor or do you have to source those yourself?
Why drive it that far? Mexico's closer!Yep, it’s driving across state lines tomorrow to
