1992 idi 73
So the school I go to I'm in a few of the different CAM classes that they offer. Since being in the classes I've doinked around with the idea of seeing of I could CNC machine some fuel return rails; much like the ones that R and D IDI have for sale. The biggest thing is that they would be made out of 1/2 PVC sheets. Knowing that the original caps are .800 inches tall but after measuring the injectors I think that I could get away with a half inch. Worse comes to worst I can source some 1 inch PVC. I have been also testing the properties of this PVC too,(see pictures below) seeing if it could even be used. So far so good. It looks like its gonna work.
I already know that the holes should be .610 of and inch in diameter for the injectors. My question to you guys is does someone have the exact measurements in between the injectors.This saves me the hassle of taking off my injections lines to measure the distance between the injectors. So any help or advice would be much appreciated, Thanks, Matt
