heres what its looks like in the cab..
Ahh. I forgot that the other gauges say NORMAL too. It's been almost a year since I drove my F250. Vans had the late 70s F-series style cluster through 91.
the 13.4 is while running at idol. i also noticed this morning whith headlights on and stoped at a light with the turn signal on and heater blowing on high it would drop down to just before the N... as soon as i start moving it goes back up too the middle... I havent taken the belts off yet might even just be loose.@Nick_Rego
hmmmmnmm
I would
Clean those connectors/connections at the alternator is a start....clean your battery terminals connections, make sure the mating alternator wires are making good contact and don’t have loose connections. Then start the truck,
13.4 volts with the truck running or off ?
How much resistance is in the alternator pulley? , belt off
does the battery light stay on or does it go away and come back on ?
where is that located?Brake light... Disconnect the vacuum warning switch.
i unplughed whay i thought made sense being called a vacuum warning switch and the light is off now. what about thst causes the light to come on?
my brakes feel ok probably beed to be bleed a little bit... another one corssed off the list and potentially more to come haha. i did tske the belts off and spun the alternator by hand and tried it for play seemed solid no weird hard spots or anything that concerned me.
But having that light come on all the time, affects your transmission, if you have an E4od. At least it did mine. Gave er about 50 miles after disconnecting that, and suddenly the trans started to act better.
The brake light on the dash, activates something else that affects the trans.
