Nick_Rego
So for those of you who have been helping me for awhile i am once again calling fo your help... This morning i have finally gotten a chance to drive my 91 f350 and ive noticed several issue that it now has that it didnt have before. first off i jump in started it up and noticed hey bettery lights on thats weird but guage shows its charging (havent gotten a meter on them yet) figure eh it will probably go away or something's just loose on the stsrter realy.. Second issue noticed the tach isnt working. it just sits at 0 the entire time. and finally when i started to drive i quiclly realized soemthing isnt right. the trans feels like its starting out in 3rd as it takes a little bit to get going from a stop unless i manually shift too mnl 1st and then i went up to two and didnt feel a diffrence and thenback to drive and it shifts and you are in third.. i dorve it work just down the road less than a mile and i noticed the overdrive light on my switch was indicating the overdrive was off which is true it will not shift out of third this trans is an e4od so im missing those last two gears.. would these be all related somehow? i looked over all the conectors I would have had contact with or could have messed with and couldnt not find anything out of place.
