Fuel spraying everywhere under the hood!!
chillman88
Central NY
If my line was cracked wouldn’t fuel be spraying around the nut? My fuel is spraying down at the cap where the rubber line goes into the injector kinda like there is no where for the fuel to go
That would be my assumption and why I assumed it was an injector problem. It certainly wouldn't hurt to verify the line isn't cracked though.
It's also possible you have a restriction in the return lines but I wouldn't expect much of a spraying so much as a dribble. The return lines are not a high pressure system. When a cap goes bad they usually bubble and seep as opposed to spraying. But if your return lines are restricted then it could be building up pressure.
Skinny Lennie
Asheville nc
I have another idi I could swap a injector and see for sure
chillman88
Central NY
You could also try bypassing the return system around that injector and see if the leak is still at the injector or moves somewhere else.
Tee the rubber lines together bypassing that injector cap. Run rubber hoses from that cap to a pop bottle or cup or bucket, then fire it up and see what happens.
Skinny Lennie
Asheville nc
I bypassed it all the spray went away but the injector I bypassed is bubbling at the bottom and blowing mist
chillman88
Central NY
That could possibly be a bad copper washer. I'd pull the injector out and see how that looks.
Where is the mist blowing from, the threads on the injector or around the plastic cap?
chillman88
Central NY
Yeah I'd try pulling it out and replacing the copper washer first. Might have to take it to a parts store to match it up, not sure exactly what size they are.
Also make sure there's only one in there, sometimes they get doubled up and cause this problem.
Skinny Lennie
Asheville nc
I pulled the injector which was loose I unscrewed it by hand. No copper washer to be found on the injector or in the engine. This is the second injector that this has happened to since I got the truck. I’m thinking about replacing the injector just gotta order one now
chillman88
Central NY
You're much better off replacing them all as a matched set from a vendor here. I understand that's not always financially possible but if you can you should, just food for thought.
Skinny Lennie
Asheville nc
I was off work today and decided to look at my situation again. I still can’t locate a copper washer so I assume it wasn’t installed. The pictures below show a hole in my plastic cap which was on the injector that was loose. I don’t know if the loose injector caused the hole but it looks like it got pretty warm and melted.
hesutton
The Anti-Anderson
Bowling Green, KY
To melt the cap like that, the injector was sticking open, allowing hot gases back into the injector. Injector gets very hot and melts the return cap. My bet is you had an injector knock too? Seen it a few times on my old '86 F250 with very high mileage injectors.
Heath
Garbage_Mechan
Garbage Mechanic
Central Cal Foothills
Likely the base problem is the missing copper washer and loose injector. The copper washer seals combustion gasses and provides a heat conductivity path. When the injector tip overheats bad things happen such as a sticking pintle which allows hot combustion gasses to come out the return flow port on the injector blowing a hole through the plastic return cap. My suggestion is to pull all injectors and verify copper washers in place, clean seating areas and proper torque. Install a new matched set and return line kit if you can.
Cubey
Van dweller
A return line kit should come with the washers.
Howard Welte
Tracy, CA
It sounds like the fuel is coming out of the return lines. There are two O rings under the caps the will crack when they are old.
There are some good videos on YouTube on how to replace them. (Pain in the ass, if you have a van type cab on your vehicle).
I ended up had to remove the injector pump and dismantal the high pressure lines from the injector pump to be able to get to the return lines.
William88
