U joints
Christopher Cline
Washington
I have a 1992 F350 CCLB and am having trouble finding the correct u joints for the rear and front drivelines. Anyone have those part numbers by chance?
Hagan
Oregon
The front at the tcase should use a double cardan joint. If your rebuilding your driveshaft are you going to replace the center ball?
Personally I use digital calipers and measure my u-joints. Then I look them up and buy them online. I only buy Spicer but it's personal preference.
Trevtron
Katy, Texas
FWIW the u-joints from my pic are all SKF, you’ll need to pay attention to the notes below the part to verify fitment for your rig.
The notes distinguish differences for the parts between transmission types and any other variables.
Black dawg
sw mt
you are wasting your time if you put those napa joints in your truck.
Rears are spicer 51350x
fronts are 51330x in the cv and a big cap 1330x at the front pinion. Don't remember that part# but I will look it up today.
the joint at the front pinion....if it has 2 caps bigger than the others, is 5-7438x.
These are all the "life series" non greasables, just like the OE joints.
From my personal experience, it's usually easier to take a U-joint out and take it into the store with you. There's what an application chart says, and then there's what's actually in your truck. If you're going to order online, measure them as Hagan suggested.
Christopher Cline
Washington
Exactly what I was looking for thank you
hesutton
The Anti-Anderson
Bowling Green, KY
Couldn't have said it better myself. Measure the size of the caps and buy accordingly. Spicer only here too. Not had good life out of chain store joints.
Heath
WarNose
Bay Area, CA
Does anyone have the Spicer part # for the center ball on the front driveshaft? Is it 10018440?
