6.9l best place for injectors?
Cainon
Smithfield
Has been knocking now a few days. Sounds like a rod bearing but everything I read says injectors. Is this common?
Randy Bush
Great Falls, Mt
Crack the lines to see which one is bad , then if really want to move to a different cyl to see if the noise follows.
Cainon
Smithfield
This is the best I could record the noise. Sorry for the quality. 0-60 phone is sitting on the dashboard
hesutton
The Anti-Anderson
Bowling Green, KY
Injector body and fuel line will typically be very hot if it is sticking open allowing exhaust gases backing to the injector causing a knock. Can even melt the return line cap.
I've had nothing but excellent results from Conestoga Diesel Injection.
Heath
lotzagoodstuff
Carmel, IN
Russ, aka Type4, is also a good source for new injectors, he’s in Oregon, south of Portland.
I’ve got injectors in stock ready to ship classicdieseldesigns.com, no core charge.
Trevtron
Katy, Texas
Injectors I got from Wes have been hammering away flawlessly for good while now, I highly recommend his injectors.
After I put them in and timed the truck it began starting within the first bump of the starter, he built them right
William88
