SirCampbulance
Hello guys I'm new here and looking for help. I have an air leak from a fitting behind the fan clutch pulley. How do I get to it. Cant find the bolts that hold on the pull . Any info would be awesome thanks
Air is coming from the fitting behind the pulley. If I push the hose in I can get it to almost stopIs it the air hose leaking?
Do you have a picture?
Just tried that still same thing. Will try to take the fan off next week.If you could get in there to the fitting with a flat screwdriver, you should be able to pop the hose loose. It should be a quick connect. Usually cutting the end off and reinstalling works.
Otherwise you may have to pull the fan, then may be able to get to the pulley bolts.
